TRUMPETS
BALL BEARING
03-14-2008 16:36:55
What is the difference between the left trumpet and the right trumpet on a 2/9n? I know that they are not interchangeable. Thanyou all. BB
Sean (TX)
03-14-2008 19:19:54
 Re: TRUMPETS in reply to soundguy, 03-14-2008 16:36:55
nevermind just read bolt patteren is different..
Sean (TX)
03-14-2008 19:18:38
 Re: TRUMPETS in reply to GA Dave, 03-14-2008 16:36:55
Could be Tom in MS problem? Trumpets on the wrong side??
rbuckel
03-14-2008 18:40:33
 Re: TRUMPETS in reply to BALL BEARING, 03-14-2008 16:36:55
I removed and replaced the trumpets on my 2N. Had bad oil leaks. I believe stud bolt patterns will prevent you from placing a left on right and vice/versa.
BALL BEARING
03-14-2008 19:10:48
 Re: TRUMPETS in reply to rbuckel, 03-14-2008 18:40:33
I believe that you are right. I wondered why the odd bolt pattern. Thanks
Dunk
03-14-2008 16:42:39
 Re: TRUMPETS in reply to Hobo,NC, 03-14-2008 16:36:55
BALL BEARING said: (quoted from post at 20:36:55 03/14/08) What is the difference between the left trumpet and the right trumpet on a 2/9n? I know that they are not interchangeable. Thanyou all. BB
Well the lower lift pin holes would be one thing.
If you used the same one on both sides, one hole would be to the front and the other to the back.
I'm not much on 9N 2Ns but then there are how the brake parts attach, etc.
Maybe that helps.
