RUST AFTER ELECTROLOSIS
BALL BEARING
03-19-2008 07:29:11
How can I prevent the rust which occures shortly after electrolosis? These are pieces (or places) that don't get painted. Thanks BB
Ed S. (IL)
03-20-2008 05:12:15
 Re: RUST AFTER ELECTROLOSIS in reply to BALL BEARING, 03-19-2008 07:29:11
Maybe it's just me, but I've noticed a lot of folks on this board have interests in flying and/or old Volkswagens besides old iron tractors.
Probably just me... ;o)
es
lonestarjeff
03-19-2008 20:04:45
BB.....I can vouch for phosphoric acid, especially if the pieces are not perfectly rust-free. If you don't want to handle the acid, another product works well too, Penetrol. You'll find it in the paint stores or Depot, etc. It can be painted over later as well.
Jeff
gahorN
03-20-2008 03:03:29
 Re: RUST AFTER ELECTROLOSIS in reply to lonestarjeff, 03-19-2008 20:04:45
On the nastyness scale.... phosphoric acid is what is in Coca-Cola (and why Coke will ruin a gun's finish.)
Tom N MS
03-20-2008 03:12:33
 Re: RUST AFTER ELECTROLOSIS in reply to gahorN, 03-20-2008 03:03:29
And has to be bad for your guts.
gahorN
03-20-2008 03:14:53
 Re: RUST AFTER ELECTROLOSIS in reply to Tom N MS, 03-20-2008 03:12:33
Similarly to the hydrochloric we make in our digestive tracts naturally.
Ed S. (IL)
03-19-2008 12:32:47
Got mine from Lowes or Menards or Home Depot (don't remember which).
Look on the shelf for concrete cleaning products.
Click for pics of my electrolysis tank
es
BALL BEARING
03-20-2008 03:56:26
 Re: RUST AFTER ELECTROLOSIS in reply to Ed S. (IL), 03-19-2008 12:32:47
Thanks Ed, Spent most of my time reading about your flying. Great!-- BB
BALL BEARING
03-19-2008 10:05:03
Thanks guys, Is phosphoric acid available at NAPA? Brand mame? What would I do without this forum? You are the best. BB
Dan
03-19-2008 12:53:14
 Re: RUST AFTER ELECTROLOSIS in reply to BALL BEARING, 03-19-2008 10:05:03
You can get the fancy-schmacy "marketed" products for $20 or so, but the main active ingredient is just phosphoric acid. I get mine at Home Depot in the paint section next to the other chemicals like Acetone and such. It is call Phosphoric Plus and runs about $13 A GALLON! I put it in a spray bottle and am ready to go. I have coated hundreds of objects and only through half of that same gallon I bought a few years back.
Oh - and I have coated objects with this stuff over a year ago and put it on a shelf - with no recurring rust.
HTH,
Dan
BALL BEARING
03-19-2008 13:24:08
 Re: RUST AFTER ELECTROLOSIS in reply to Dan, 03-19-2008 12:53:14
Thanks Dan, just the info I needed. Is Phosphoric nasty?
Dan
03-19-2008 15:05:32
 Re: RUST AFTER ELECTROLOSIS in reply to BALL BEARING, 03-19-2008 13:24:08
Others may dissagree - but on a scale of 1-10 for "nastyness" I would give it a 5. It will burn your skin if it sits on it for too long, but I have had carb cleaner that burns worse.
Dan
Ed S. (IL)
03-19-2008 09:38:20
Phosphoric works great, but not indefinitely (maybe a few months).
Ask me how I know... :roll:
I will shortly be derusting my tractor for the third time. Hopefully I'll actually get it together and painted this time!
es
Dan
03-19-2008 08:26:23
I like phosphoric acid. It quickly kills the flash rust and coats the metal to keep it from rusting again. I keep it is a spray bottle and coat just about any metal after I clean it. As a bonus - you can paint right over it.
Dan
soundguy
03-19-2008 07:33:41
If these are piece that you need to store after rust removal, you can always hit them with an oil of grease / fluid film.. then clean them up later for painting.... if they are pieces that will never get paint.. what about clear coating them?
soundguy
soundguy
03-19-2008 07:33:33
soundguy
