V drawbar
sgt bull
04-04-2008 18:39:36
I saw a "V" drawbar on Ebay for the N series tractors today. Is there any real advantage to it over just hooking to the crossbar between the lift arm ends?
norbert kanzler
04-05-2008 14:46:46
 Re: V drawbar in reply to sgt bull, 04-04-2008 18:39:36
mr. bob, I am very interested in the arrangement you made to use a normal 8N swinging drawbar on your 2N. I have tried to make a rig for my 9N but have not been able to make it work. Could you post drawings of what you made?
Dell (WA)
04-04-2008 19:52:17
Sarge..... ...the "V" drawbar conversion works well for 9N's-n-2N's for NOT having those "under-the-diffy" 4-boltholes for swinging drawbar mounting bracket. ONLY the 8N diffy has the 4-holes drawbar pulling adapter. The advantage of the diffy mounted "swinging drawbar" is NO LIFT-UP when BACKING using the 11-hole crossbar. While you can keep the 11-hole crossbar height constant (as when using the "V"-bar) with those wimpy adjustable "stay-bars", they will fold on you when backing-up..... ..Dell
Mr. Bob
04-05-2008 14:24:29
 Re: V drawbar in reply to Dell (WA), 04-04-2008 19:52:17
I made and use an 8N style under mounted swinging drawbar on my 2N. All I had to do was fabricate a bracket to function the same as the diffy mounted bracket which boltz on an *N" or "Hundred" series. It has worked perfectly for me for several years pulling heavy loads. Those "V" drawbar contraptions are real monstrosities as I see it, I think the under mounted swinging drawbat is better beyond compairson. Mr. Bob
award
04-05-2008 09:04:35
 dell in reply to Dell (WA), 04-04-2008 19:52:17
dell, for my 8n i was thinking of getting a drawbar setup for pulling a trailer. i have the drawbar wor the ball, but here is my question:
are all of the setups the same quality? are some china mans and are they rigid enough? i would rather buy american if i can. any help?
Dell (WA)
04-05-2008 12:44:43
 Re: dell in reply to award, 04-05-2008 09:04:35
award..... ...dunno iff'n you have the "option" of US made or ferrin maid.
I have 2-under the diffy swinging drawbars, one came with the tractor in 1990 and is double-bent, 1-natural, 'tuther' from overload. I like my "new" (India?) swinging drawbar better and I ain't bent 'nuttin' yet. I tow 7000lb ball/socket hitched trailers around the property.
Even though the 11-hole drawbar has a "neat" advantage of hydraulic lift for picking-up trailer hitches, I don't like it 'cuz it ROTATES without a "lock" and lifts without staybars.
There is a square tube based 3-point hitch which doesn't rotate and is hydraulically liftable, but I'm happy with my under the diffy mount swinging drawbar. I did drill out the 3/4" hole for 2-5/16" ball stem. (1" dia)..... ...Dell
lonestarjeff
04-05-2008 10:16:24
I'm not Dell, but I'd say nothing wrong w/ looking for an original.....& yes, the old ones are likely made tougher than the new repops. Not sure if you'd ever notice the difference unless you really move heavy stuff.
Have you thought about a swinging drawbar setup instead? It would be a safer way to move your trailers.
Jeff
award
04-05-2008 12:35:46
 Re: dell in reply to lonestarjeff, 04-05-2008 10:16:24
not sure of the differences. if you have a link to the options and opinions i would be greatful.
