reciever hitch (sorta o.t.)
Rob N VA
04-11-2008 05:21:33
Does anyone know where I can find a 3 point attachment that will allow me to put a regular truck tow reciever in. My goal is to use my 3 ball reciever on my tractor so I don"t have to change balls every time I need a different size ball, but I can"t find a 3 point attachment that will work. Any help would be appreciated. Thanks for your time!
Rob
jon
04-11-2008 17:26:52
 Re: reciever hitch (sorta o.t.) in reply to Rob N VA, 04-11-2008 05:21:33
Dunk said:
Interesting you should say that.
My scrape blade has holes to vary the pitch, frontwards, or backwards.
Lots of times I have bolted a ball in the ones to the rear, and moved a trailer, or a boat around.
Interesting you should say that, mine has holes on it too but I never thought about using it. May give that a try.
Great minds think alike? :lol:
Dunk
04-11-2008 16:43:52
 Re: reciever hitch (sorta o.t.) in reply to don b, 04-11-2008 05:21:33
jon said: (quoted from post at 19:59:37 04/11/08) I've been meaning to cut a hole & weld a reciever in my box blade since it seems to be on the tractor more than anything.
Your mileage may vary though.
I also used them to bolt the trumpet to, so that I could put the required torque on the lower lift pins that I replaced, thanks fellers that had input on that job.
third party image
Larry59
04-11-2008 16:31:04
WOW... got call from another guy on form about this showing how to do it. Just what I am going to build to. Thanks. Made my day. *S
jon
04-11-2008 15:59:37
old-9
04-11-2008 14:49:16
I bought an old reciever for (something?) at a sale and cut and welded together what you are looking for. Cost $10.00 or so. I would send or post photos, however gave it to my son.
joe
MikeRW
04-11-2008 13:12:36
Its not a 3 point attachment but I had a receiver hitch custom made so that it bolts onto the underside where you would bolt on the draw bar. Had the square stock welded to 1/2" plate so that the 2 bolt holes toward the front of the tractor were totally in the clear of the square stock and then the two bolt holes in the back are extremely close to the square stock to you need to use Allen Head grade 8 bolts. So far it's worked great.
roger '40 9n
04-11-2008 06:59:18
Northern tool has one not too pricey.
Link
Roger
PhilipIN
04-11-2008 06:23:36
third party image
I have AutoCAD drawings for this. Send me a private e-mail and I will send you plans. Philip.
GB in MT.
04-11-2008 05:33:40
Rob;
I can't remember who made and posted this, but here it is, so you can see what they look like. And yes you can buy these already made, on various sites, on the internet.
third party image
HTH
Gary 8)
Marty 2N IL
04-11-2008 05:28:25
I am pretty sure that this site sell them. I know Northern tool sells them also. I made one for my tractors it works great let me know I can send you a picture. I had it posted before you might be able to do a search for it.
