any brilliant ideas? previously bust bolts in diffy housing
award
04-19-2008 08:25:40
alright folks, i need a brilliant idea on getting these 4 snapped bolts out of the diffy housing. they were snapped off 1/4" deep long time ago.
i have the hitch waiting to be put on but it looks like it won't happen now.
and alternate idea is to use my multi-hole draw bar(not part of the kit).
i could use the drawbar between the lower links. then rig up with two "L" shaped flat bars. the flange parts can bolt to the draw bar and the top link can fit between the two flat bars while being pinned.
instead of making this does anyone have a source for purchasing something like this?
Dunk
04-19-2008 20:33:07
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to don b, 04-19-2008 08:25:40
Dunk..John,PA said: (quoted from post at 00:23:48 04/20/08) Careful check'N your fuel with YOUR hammer during thunderstorms..... ... John,PA
Beertender!!!
Beertender!!!
I'll have three of what John is having!!! And give him one more!! On my dime!!
John, I hope you ain't flyin nothin mechanical tonight.
Gaspump
04-19-2008 08:37:25
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to award, 04-19-2008 08:25:40
No brilliance involved at all, just some hard labor and good tools. If they were mine (I have done some like yours) start by cutting the bolts near flush with the housing, center punch them and using left hand drills start with a small size and work up to at least 3/8". If they are not out by now try a tap extractor. If it doesn't work some heat then the the extractor will.
award
04-19-2008 08:27:16
oh, the holes with the snapped bolts are in the diffy housing for the swinging draw bar.
Dell (WA)
04-19-2008 08:38:01
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to award, 04-19-2008 08:27:16
Award..... ...its called WELDING (upside down, grin)
While NOT EAZY, a good welder could weld some NUTS in the hollow centers. The HEAT from welding will usually "un-freeze" yer broken bolt parts and you can usually un-bolt with semi-eaze..... ...Dell
DELL..OT John,PA
04-19-2008 11:44:33
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to Dell (WA), 04-19-2008 08:38:01
MY future is head/N back home to KDEN, and, I ain't doi'N the fly'N. SHE IS!!!!! !!!!
Make'N me nervous. THANKS..,mnbgtuyipoJohn,PA
award
04-19-2008 09:14:26
i don't mean to complain but it just irks me. now i can't find the penetrating fluid in the spray can. i do have kroil but its for guns and it won't squirt upwards. now i have to go to town. can i scream now?!!!???!!!!
oh, and harley davidson syn3 motor oil is not what they claim. a guy is better of putting amsoil in it(the harley).
What's wrong?..John,
04-19-2008 14:23:06
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to award, 04-19-2008 09:14:26
Last years drain's? Douse her up GOOD. Come back next week//////////
John,PA
gahorN
04-19-2008 11:48:51
Nawww! Ordinary SAE 50 wt (also known as 100W) AEROSHELL aviation oil. It's for air cooled motors, and it's cheap. ($3qt) at all local airport refuelers.
Listen!!!! Johgn,PA
04-19-2008 12:22:28
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to gahorN, 04-19-2008 11:48:51
I even "pleaded" to Magellan(tm). Ain't there some utter place in the WORLD to go to except KDSEN????? ? Pictures, lat's, and long's!!!!! !
They listened!!!!! !!!!! !!.
PUBLIC INFO>>>>>>>>>>>>>>
John,PA
No Problem..John,PA
04-19-2008 12:45:40
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to Listen!!!! Johgn,PA, 04-19-2008 12:22:28
Except for ALA mAATERS.
derstqand "FRENCIE BOEINGS".
ARRIVAL GWTE????? ????? ?
Thansks, DUNKIE
Dunk..John,PA
04-19-2008 20:23:48
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to No Problem..John,PA, 04-19-2008 12:45:40
Murn Ga
04-19-2008 16:06:01
John, has no one ever told you to stay off the www when you have one of those meth pills? Just wondering.
YIP..John,PA
04-19-2008 20:21:39
 Re: any brilliant ideas? previously bust bolts in diffy h... in reply to Murn Ga, 04-19-2008 16:06:01
Is dat dem little "blue" pills?
:0)
