Order Ford 8N Parts Online
8n loader hydraulics
BDC
07-05-1999 19:39:54
I have an 8n that I took the loader off of and there is a threaded tube that is left sticking out of the inspection plate that the hydraulic hose was hooked to. Is that tube hooked to a pump and can i remove this somehow.
bg
07-05-1999 20:58:49
 Re: 8n loader hydraulics in reply to BDC, 07-05-1999 19:39:54
Sounds like someone did some plumbing. Take the plate off and look and see what they did. Without knowing what was modified, it's tough to say what it will take to fix it. You could also remove the hydraulic cover and get a better idea. You'll likely have to remove it anyway to fix it.
