Order Ford 8N Parts Online
Ford 8N missing badly
B bar C
07-12-1999 16:33:57
Ford 8n, used for basic small time ranch work (mostly working arenas) with a new distributor, oil, gear oil, coil, points, etc..., basically been kept in decent shape. Started smoking from oil resevoir up thru the oil cap, odor is not good. Been running great, all of a sudden started smoking and missing, turned off, won't hardly restart, adjusted distributor to keep running but its running like crap ever since it started cutting out. Any clues ?
hows your........Dell (WA)
07-12-1999 21:48:17
 Re: Ford 8N missing badly in reply to B bar C, 07-12-1999 16:33:57
oil pressure??? sounds like your oil pump puked. and you are "splash lube-ing" your crankshaft bearings. Just hope you haven't scored your crankshaft journals and bearings and welded them together....
Hope I'm wrong..... ..Dell
Robert
07-12-1999 17:26:51
A good place to start here might be to check engine compression. You may very well find one cylinder with little or no compression.
George
07-12-1999 20:01:08
 Re: Re: Ford 8N missing badly in reply to Robert, 07-12-1999 17:26:51
Try compression check; sounds like you may have excessive blow by may need valve guides seals and new valves not to hard to do but time comsuming
