Order Ford 8N Parts Online
8n info
B. Dugan
08-28-1999 23:02:52
Gents, I need a litle help with my new ford 8n. first, the pto. When using a brush hog what is the name 0f the saftey implement which is utilized when running the brush hog. second, how easy or difficult is it to change the rear seal in the pto...any words of wisdom?
bg
08-29-1999 04:52:58
 Re: 8n info in reply to B. Dugan, 08-28-1999 23:02:52
The device is an "over-running" coupler or clutch. They cost anywhere from $40-70 and are available at most farm or tractor supply places. Make sure you get the right size for your PTO shaft. The original stock 8N shaft is 6-spline 1 1/8". Many have been changed out for the more standard 1 3/8" 6-spline.
To change the seal, you remove the 4 bolts holding the housing , pull the shaft out, replace the seal and stick it back together. If you park the tractor nose down in a shallow ditch(block the wheels well) you can pull the PTO shaft w/o draining the fluid.
