Ring gap
BIIIN8N
11-21-1999 10:03:53
What is the proper pistin ring gap for the 8n 1948 . new pistoms and sleeve .
tks
Bill
Ed Gooding (VA)
11-22-1999 04:06:12
 Re: ring gap in reply to BIIIN8N, 11-21-1999 10:03:53
.007 - .017 on the top compression ring
.010 - .017 on the 2nd compression and oil rings.
Be sure to stagger the gaps 120 degrees apart on each piston.
Hope this helps..... ..... Ed
'52 8N475798
Engine man
11-21-1999 18:38:12
I have always used .003" per inch of cylinder bore (diameter) to calculate ring gap. It works very well on most gas engines. For example: 4" bore x .003= .012" end gap. I've never had a problem yet.
TimK
11-22-1999 07:20:52
 Re: Re: ring gap in reply to Engine man, 11-21-1999 18:38:12
My 1995 FO-4 IT manual says .010-.017 for all rings.
