Order Ford 8N Parts Online
8N RESISTOR
BARRY H.
03-21-2000 10:35:24
I HAVE AN 8N WITH A FRONT DISTRIBUTOR THAT IS STILL A 6 VOLT SYSTEM. SHOULD THE RESISTOR GET SO HOT THAT YOU CAN'T TOUCH IT? THANKS IN ADVANCE!
JamesC.
03-21-2000 11:27:48
 Re: 8N RESISTOR in reply to BARRY H., 03-21-2000 10:35:24
Yes the resistor will get very hot when the engine is stopped and the points are closed with the ignition on. While the engine is running the resistor will be cooler.
The resistor keeps your coil from burning up.
