Kabota problem
robert jordan
01-26-2002 18:12:24
I bought a used 3 cyl kabota diesel and instaleed it on the side of my semi. I am using it to keep my truck warm when I sleep and to prewarm the truck before I get in it after a few days off. The problem I'm having is after about 30 min. the motor will act as if it's out of fuel and quit running, after a minute it will restart but will only run a short time and then stop again. I have a new eletric fuel pump, new filter and water separater.
Don Hegwer
09-08-2002 21:42:09
 Re: kabota problem in reply to robert jordan, 01-26-2002 18:12:24
I keep getting air in my fuel system, I've replaced my primairy pump and all the hoses even inside the fuel tank. Could a bad injector possiably be allowing purge stroke air into my fuel pump? Any ideas???
Don Hegwer
09-11-2002 12:12:49
 Re: Re: kabota problem in reply to Don Hegwer, 09-08-2002 21:42:09
My #2 injector consistently had more air in it than the rest,(while bleeding system).
I replaced this injector and everything is fine now. Thanks for the advice, Don
Scott
07-14-2002 04:45:05
b7300 blew a trans seal pretty stedy leak thank its from trans were drive shafts go in
want to know if hard to fix?
thanks
Bill Blankinship
03-03-2002 10:02:30
Have a bobcat with a Kabota 2 cyl.diesel (about 1980) & We need to overhaul the engine going 20 thousands over on bore. We are in Tucson Arizona. Where can We get engine overhaul parts, sets, etc.?
GEO
01-26-2002 18:58:43
Had a ZTR lawnmower that had a small Kubota engine on it that did the same as yours. I took the black hose off going to the inj. pump from the filter and put on a clear hose. Started engine and watch for air bubbles. Found one of the hoses that came from the tank had a pin hole in it. Ran fine after replacing it.
David Zink
06-28-2002 20:01:59
 Re: Re: kabota problem in reply to GEO, 01-26-2002 18:58:43
I have a woods attacthment that fits on my kabota and need the part. The woods attatchment is the backhoe and would like a responce
