Drive shaft tractor
goatman
12-23-1999 17:46:24
several years ago i came across a tricycle tractor that had a driveshaft in it. seems like it may have been oliver green but i ain't sure, anybody??
wayne
12-24-1999 14:06:12
 Re: drive shaft tractor in reply to goatman, 12-23-1999 17:46:24
I'm not an expert on this but some Olivers had a drive coupling.
Steve T
12-23-1999 18:44:30
The Farmall F-12 and F-14 had a short coupler between the engine and rear end/transmission. The early Farmalls were painted grey, so its possible that that you seen an early Farmall. Not sure who else used this set-up.
Steve T
goatman
12-23-1999 20:05:24
 Re: Re: drive shaft tractor in reply to Steve T, 12-23-1999 18:44:30
Steve, this thing did'nt look like the f12 f14 pictures i've seen. may have been though. did have rubber tires.
Steve T
12-25-1999 22:21:07
 Re: Re: Re: drive shaft tractor in reply to goatman, 12-23-1999 20:05:24
HHHHmmmm, Not sure then, if I come across anything, I'll leave a post. Steve T
G F
12-26-1999 17:13:06
 Re: Re: Re: Re: drive shaft tractor in reply to Steve T, 12-25-1999 22:21:07
Although the're red B.F. AVERY'S had drive shafts
in them
