Painting with aluminum paint
Sand Flat Bob
04-17-2007 13:21:54
This is not a tractor but a tubing gate, painted, and is little rusty. Do I need to prime this or just paint with Aluminum paint. I know if it is regular paint, it would have to be primed.
Thanks!
Bob
glennster
04-18-2007 06:02:45
 Re: Painting with aluminum paint in reply to Sand Flat Bob, 04-17-2007 13:21:54
i'd wire brush the rust off at the very least. see what primer the aluminum paint recomends as a base coat. if its a rust-olem aluminum paint, they have a heavy rust primer and a new metal primer available. i agree with circus that the aluminum paint may not be the best choice for a gate as it is handled quite a bit. then too if there is livestock they may be prone to licking the aluminum. try an alyky paint in a light gray.
Sand Flat Bob
04-18-2007 06:47:18
 Re: Painting with aluminum paint in reply to glennster, 04-18-2007 06:02:45
Glennster, that is good suggestion. I was thinking aluminum because I need to repaint my propane tank, but a regular metal paint would be better. The horses chew on everything. Think I will go the alky route with a primer. Have two of these gates to do. 2 inch tubing that were just painted and not a very good paint job either. Thanks!
Bob
circus
04-17-2007 17:42:44
Painting anything that's rusty wont last. Aluminum paint is a strange animal. Every time you grab it you'll have silver hands.
