Clearcoat Over Decals?
Rod (NH)
05-26-2002 17:07:02
Has anyone used a clearcoat over the cut decals that you get from Lyle Wacker? I am considering using a clear acrylic urethane over them and was wondering if that might cause any problems with the decal.
Rod
Thanks Guys...n/m Rod (NH)
05-29-2002 07:28:25
 Re: Clearcoat Over Decals? in reply to Rod (NH), 05-26-2002 17:07:02
n/m
Tom
05-27-2002 18:13:16
Yes. But I am not familiar with Lyle Wacker decals, but if they are from who I think they are from; or to put another way, if they are plastic or acetate stick-on type...you're good to go.
I've done it with stick on type and the type that require a dip in a mild solution of windex to apply with good results.
It looks nice and they are protected. I didn't need to scuff them but it wouldn't hurt as long as the ink remains intact of course.
Use a pice of the same material and do a test first. DOesn't hurt to order an extra in case....
Tom
05-27-2002 18:12:15
Cliff Neubauer
05-27-2002 07:00:57
I haven't done it personally but I know a local body shop has clear coated over decals before with seemingly good luck. He lightly scuffed them with a scotch pad first.
