Rick from NC
Stripped my Ford 4400 down in the fall. Painted the chassis with MP170 & unhardened MAE in late October. Worked on the sheet metal through the winter and have it primed w/ MP170 & MP281 surfacer. (yes I work really slow) I decided to bite the bullet and buy a supplied air system so I could use hardner on the sheet metal and upgrade to 2k surfacer/MTK on future projects. I know I risk lifting but I'm considering shooting several coats of hardened MAE over the unhardened MAE I shot on the chassis last October. My main question is how long will it take for lifting to occur? If I do a test area should I wait a couple of days?, a week?, a month? before knowing the result. The main reason I want a hardened topcoat on the chassis is for resistance to gas & oil spills but I also want to change the color a little. I painted the chassis with PPG code 12908 which is actually Equipment Dark Blue instead of 12809 that I intended to use which is Tractor Blue. Don't ask how I screwed that up. I'm still not sure myself.
