OK, I know you are not supposed to, but here is the situation. I started on this project (Farmall Cub Lo-boy) several years ago. I am finally to the point of getting it back together. When I started, our local shop was a PPG dealer so I went with the DP50LF epoxy primer on the chassis. I am obviously past the window on recoating many of the parts so I plan to scuff and shoot another coat of epoxy. We already talked about the hood/gas tank which is the only major part not in primer yet in an earlier post. Our local dealer is now a Dupont dealer. Can I put Nason over the DPLF? And since I will need another coat of epoxy (and I don't think I have enough of the DPLF anyway) should I use the Dupont epoxy or search out another PPG dealer? Thanks.
