So, what rattle can paint is the best?
Nofbdybs
Going through the process of touching up our JD 420T.
Lots of small parts I plan to hit with the rattle can. That in mind, who makes the best spray can paint, with the most accurate color matching? Typical JD yellow and green. Also, should I just use a quality primer in standard gray?
CaseIH makes the best for the newer IH colors, JD is probably the same. I think both are made by Valspar. Stay away from tractor store paint. JD may not sell paint for the older tractors, though.
Be careful with your selection on these if you are goin for a lasting restoration or whatever. I have used a brand that looks good for a while and then kinda chalks out after only a few months.
I have had success with the Valspar brand. Not sure if you can actually get the correct shade of JD green through anyone but the dealer. Not to sure if it is available in rattle can.
