TJ in KY
What should I do about this pitting on brake backing plate? I have not done any painting with epoxy primer, a little intimidated by that process but willing to learn. I have been reading old post to try to educate myself but dont know what to do with these backing plates.
Should I
1. Use Picklex 20 or Must for Rust first to convert rust deep in pits then prime with epoxy (2 coats), then filler primer (several coats) till i am happy with results
2. Picklex 20 or Must for Rust, but then body filler then, epoxy then sanding primer
3. Use no Picklex 20 or Must for Rust, Use some type of body filler, then epoxy then sanding primer
4. Buy new backing plates
When I first started this process I thought cost would be no object, but cost are quickly adding up. If I can save these I want to give it a try. It would probably be a good learning experence, could allways strip whatever I have done or buy new.
Or any other options that i may not have thought of??
Should I
