TJ in KY
I will be using PPG MP 170 epoxy primer and the tech sheet says under mixing instructions that acetone can be used for an additive up to 10%.
When is an additive needed, is acetone used to thin the paint?
This is my first time using epoxy primer just want to be sure i have what i need and when to use the acetone, if needed,
Thanks for your patience, i know i have asked a lot of questions but just want to have a successful outcome.
Tom
Tom
