TJ in KY
I recently painted a rim with Omni MAE using MR 186 medium reducer over epoxy primer and I am pleased with the results. There are a few areas I scrached on the edge of rim and I want to touch up using a brush.
What I am not sure about is if I need to mix the MAE with the reducer as I did when I sprayed the rim.
Or to put it another way, is the reducer just an aid to thin the paint to spray it or is it needed for some type of chemical reaction to help it dry.
The scratches are not thru the epoxy so this is just for looks.
