thinning paint
rick
10-20-2003 09:33:07
How can i tell my paint is thinned to the correct consistency for spraying. I read, if correct that 4 drops of paint should fall off the stir stick. Can someone give me a good understanding of this or the correct method.
CNKS
10-20-2003 18:17:26
 Re: thinning paint in reply to rick, 10-20-2003 09:33:07
Others know more about mixing than I do, but I use PPG paint and use the ratio that the spec sheet says, NO modification. It has worked so far. The cheaper paints may allow room for, or require experimentation. Those with more experience than me may have good luck with modifying the recommended mix for quality paints. I don't know because I haven't tried such modifications. Read the posts below this one, as I believe Gene mentioned something that works for him, it may work for you. My belief is that if you buy quality paint and follow the manufacturers recommendations, that any problem will then be my fault, such as improper gun adjustment.
