. As noted, mine is not an "official" compressor for such a purpose but I decided, at least for me, that it was an acceptable risk. It has served me well for a long time.I would seriously question whether a compressor sized for air brush use had enough capacity for breathing air purposes. You should have 4 cfm minimum for a facepiece or 6 cfm minimum for a hood.
The Hobby-Air system that CN uses is a very popular one for the part-time user; at least that is my impression from all I have heard about it. Since it is sold as a system, one doesn't have to cobble together parts on their own to make a complete, functional, relatively low cost unit. I say relatively low cost because there certainly are other complete packaged systems but all are significantly more than the $500 or so for the Hobby-Air.
3M makes a lot of very good products but I don't particularly agree with them if they say it is OK to use a shop compressor for breathing air if it has a particulate filter. There is more at issue than particulates in using shop air for breathing. Namely oil vapor and potentially carbon monoxide. An "official" package for such use would normally include a carbon "taste and odor" filter to handle oil vapors and a CO monitor/alarm in addition to a particulate filter. There are belt-pack units marketed for that purpose and perhaps 3M also sells one. Although one might want to take the risk of not having a CO monitor/alarm, I have found by past experience that the oil vapor can be a problem. Before I got my dedicated compressor, I tried supplying my full face mask with shop air. I had a distinctive oily "aftertaste" that I found objectionable and decided that I did not want to breathe such stuff. There is also the capacity issue. Unless you have plenty of extra compressor capacity, robbing a full 4 cfm for breathing may make you short of air for supplying a full sized spray gun for any length of time.
I think Butch uses shop air successfully for feeding a mask so he may stop by and provide some info on his experience. I just don't like the idea. I have a personal dislike for taking any kind of air that is not acceptable to breathe and processing it by means of special filters, etc to yield good results. I don't think it is the best approach. Not while there is a reasonable alternative readily available. That reasonable alternative is, IMO, using a source of already clean fresh air supplied to the mask by a system that is not capable of adding any harmful "stuff". That can be accomplished by either a non-lube tankless "compressor" (diaphram or piston type) or a turbine/blower like the Hobby-Air system uses. If you use such a system you should plan on using at least 50 feet of hose to permit locating the compressor/turbine in a known clean air environment.
Rod
