JD 60 pulling tires
berryf
07-26-2003 20:29:47
ihave started pulling my 60 in local pulls, 6000 to 8000 lbs. I always spin out it only has 13.9-38's what would be the best tire size to replace these with???? Ipull in stock classes and Ibelive the tractor has plenty of power thanks
Ken C.
07-27-2003 19:15:10
 Re: JD 60 pulling tires in reply to berryf, 07-26-2003 20:29:47
Run it in first gear and go with the biggest tires your rules will allow, 18.4 x 38 is what i use. Your slow first gear, should not power out.
sos puller
07-26-2003 20:59:11
16.9x34 or 16.9x38 depends what gear you try two pull in.
berryf
07-26-2003 20:42:04
I meant 13.6-38s
2 Cylinder
07-27-2003 19:11:15
 Re: Re: JD 60 pulling tires in reply to berryf, 07-26-2003 20:42:04
My suggestion would be 14.9 X 38's if the tractor is stock, if you have a little more than stock horsepower then go with the 16.9 x 38's. I would recommend the wide angle bar Firestone's or Armstrong's which are now called Titan's at least 1/2 worn. These are the two brand tires that I use, with good success.
