D-17
Adam
01-05-2004 19:42:49
I recently bought a D-17 and the exhaust gaskets are bad on it. I was just going to fix some little things on it and then try and makes some money. Well the exhaust doesnt sound to appealing so I was thinking if I'm going to take the manifold off is it possible to just swap it out with the one on my WD. Will this improve the performance of the WD any? Also are the heads interchangable without having to shave it down or anything. I havent measured anything on any of this. Just thought maybe someone could just tell me and save the trouble. Thanks
Big D
01-05-2004 20:52:40
 Re: D-17 in reply to Adam, 01-05-2004 19:42:49
The heads will interchange, rocker arm posts will be shorter on D17 so keep them with the head. Probably a waste of time on a stock engine, like the thin head better anyway. Manifold and carb won't gain u much on the stock engine eather, but u will get a little hp at higher speed.
Allis Puller
01-05-2004 20:01:05
They are interchangable - but your WD may have the "short" head. You'll know when you compare the two one would be taller than the other. The D-17 will also have a bigger carb.
