wd 45 puller
BP
05-11-2004 19:01:38
I have a WD 45 I'm wanting to turn into a puller. Looking for any advice on a good engine/drivetrain combination or modifications before I do a complete rebuild. I have a wc, wd, & wd45. I see alot of people pulling with wc's & 45 engine. Is there a drivetrain advantage with the wc? Or should I stick with the whole wd45 package.
KBMO
05-12-2004 08:50:39
 Re: wd 45 puller in reply to BP, 05-11-2004 19:01:38
The WC is lighter. Other than that I don't see a real advantage. I prefer starting with a WD. They can be made just as light and you already have foot brakes. If this is going to be a div II type tractor alot of places won't let you run a 45 block in a WC. If you are going Div III or higher it is fine or a D-17 block either one. Keep in mind a WC and a WD both have a higher first gear than a WD-45. It really all depends on what classes you are going to build it for.
Mike in Mo
05-13-2004 14:44:04
 Re: Re: wd 45 puller in reply to KBMO, 05-12-2004 08:50:39
Hey Ken, Does the UGLY STICK live yet? If not why doncha build some more weight brackets for your WD so you can pull 6500/7500 with the REAL (green) tractors!! :-) See ya saturday, Mike
larry
05-11-2004 19:25:15
wc is the best in my opinion you dont have to worry about the hand clutch to loose pwr from slipping clutch a hand clutch on 45 also a stock 45 en will not win many pulls you need a minimum of 4.125 bore and wd only pistons for added compression with awd45 crank or stroker crank big money ad17 carb and manifold , gov spring d17 or 175 12v ignition electronic to give hot spark and for starting with added compression tires 14 -9 or 15-5 38 in rims stock tires not very competive unless your pulling around no hot shots good 3 angle valve job and chevy 396 valves
