Hey Chad S IH 350 Carb
Allen West
09-21-2004 17:28:39
How do I go about changing my jet size in my IH 350 carb? By the way you are saving me alot of headaches.
ChadS
09-22-2004 06:45:16
 Re: Hey Chad S IH 350 Carb in reply to Allen West, 09-21-2004 17:28:39
On page 8 of this tractor pulling forum, step by step information on rejetting the IH carb. Check it out. just look for the posts, not hard to find. ChadS
ChadS
09-22-2004 07:41:29
 Re: Hey Chad S IH 350 Carb in reply to ChadS, 09-22-2004 06:45:16
All the work is done to the bowl of the carb. Remove the bowl, disassemble it, go to the hardware, and find the drill bit that matches the main jet, then buy the bits that are 4-5 sizes larger than the stock jet size. That will be the new jet size. next, you have the long brass metering stem in the center of the bowl, use the same bit, and drill out the bottom 2 holes in the stem. This matches up the main jet size, to the metering stem. Be careful on drilling ou the main jet, dont go too deep, or you will drill into the casting. you just drill the brass jet. Hope this helps, ChadS
