I NEED SOME HELP
BUCKMASTER
02-18-2005 20:26:34
OK GUYS IVE GOT A 52 SUPER M THE GOUVNER IS LEAKING OIL OUT THE BACK SHAFT I KNOW WHERE 4 GOVENERS ARE ONE IS A M&W OFF A SUPER M ONE IS A H ONE IS A REG M I PULL THIS TRACTOR AS WELL AS WORK IT HERE ON THE FARM SOME WHAT DO YOU ALL THINK WOULD BE THE BEST IVE BEEN TOLD THE H GOVENER HAS LIGHTER WEIGHTS IS THAT GOOD I PULL 5500-7500 LB CLASSES I WANT WHAT WILL DO ME THE BEST JOB IT IS NOW RUNNING 2200 RPM THANKS
CLARENCE BARENIE
02-19-2005 06:22:01
 Re: I NEED SOME HELP in reply to BUCKMASTER, 02-18-2005 20:26:34
I THINK YOU WOULD BE VERY DISAPPOINTED WITH THE H GOVENOR, I've tried tha once, almost missed a pull, changing govenors in the middle of the night. (h) govenor, you ought to be able to run 3000rpm's. buy the m@w govenor, put a little shorter spring in it,(if you have to) it will turn 2200.
just my 2-cents
also, how much slop in the weight's, are they rocking on the pins. (rite to left)
ChadS
02-20-2005 07:33:20
 Re: I NEED SOME HELP in reply to CLARENCE BARENIE, 02-19-2005 06:22:01
Bud, why didn't it work? Ive done that many times and had good results. Yeah, you can up the rpm limits using the H governor, but, you have to reset the upward liknage to make it work,, you can't just bolt it together,, you have to readjust the verical linkage. Not just swap them out. it is trying, but once you sit down and set it right, it will work as good as the M governor. Stay away from the M&W if you can,,, unless you intend on running no more than 2000 rpm, it is hard to get the rpms up on a stock M&W governor. Springs help, but,,, you have twice the amount of weight closing the governor down,, VS a 2 weight governor. ChadS
cclarence barenie
02-21-2005 15:46:44
 Re: I just read this in reply to ChadS, 02-20-2005 07:33:20
heavy on the govenor !
lite on the distributor!
something about mass in motion !
Chad ,ain't got all the answers yet ! (okay) don't profess to have !
I firmly disagree !
