John Deere 60 LP
ADroopy
04-02-2005 12:32:35
I have a John Deere 60LP that I want to use for stoneboat pulling. The motor needs to be rebuilt. I would like to get some more power out of it, do you build a propane motor in the same maner as a gas?
buickanddeere
04-02-2005 15:11:11
 Re: John Deere 60 LP in reply to ADroopy, 04-02-2005 12:32:35
Yes but why? For stone boat pulling you don't need HP. You need traction and balance in order to use that creeper 1st gear.
Adroopy
04-02-2005 18:09:21
 Re: John Deere 60 LP in reply to buickanddeere, 04-02-2005 15:11:11
I would like to pull with another club that has a transfer sled. They have about 5 pulls about 10 min. from my place.
buickanddeere
04-03-2005 11:57:30
 Re: John Deere 60 LP in reply to Adroopy, 04-02-2005 18:09:21
Power-bloc & more compression. Nail head shaped intake valves. Use a larger valve seat cutting tool and remove about 1/8 or 3/16" from the "eyebrow". Three angle valve job. Match the carb,manifold & heads so there are no sharp edges. Blend all the rough edges and casting flash out of the ports. Install a cam from Robert's Carburator. Dry aircleaner conversion from Albert. Up the LP vapour flow in the carb using 720 LP orfices. Maybe even larger to prevent leaning out? Pertronix ignition modual and matching coil, solid plug wires and 3116 Autolite plugs. Tune and dial in the whole combo on a dyno instead of guessing. Remember. You are not working with a engine design for racing. That engine was made to burn cheap oily sludge the refineries had no market for in the 1930's and 40's.
Adroopy
04-04-2005 14:17:00
 Re: John Deere 60 LP in reply to buickanddeere, 04-03-2005 11:57:30
Could you give me more info on the dry aircleaner conversion from Albert?
buickanddeere
04-04-2005 15:09:38
 Re: John Deere 60 LP in reply to Adroopy, 04-04-2005 14:17:00
Albert Ulrich who owns Renaissance Tractor in Washigton State ( I think?).
