vinson manifold ?
Another M pulle
04-17-2007 10:53:16
I have seen references to vinson manifolds on here.How do you identify one?I have a couple of aftermarket replacement m Farmalltype the runners branch off a bit closer to the carb. Above th e carb it is flat with 4 little cast in bumps.arethese them?Also for what raeson are they better than stock?
Does anyone have any dyno figures vs factory?Thank you.
Charles McNelly III
04-17-2007 15:20:45
 Re: vinson manifold ? in reply to Another M puller, 04-17-2007 10:53:16
Send me a picture.
Charles
ChadS
04-20-2007 08:45:26
 Re: vinson manifold ? in reply to Charles McNelly III, 04-17-2007 15:20:45
They have VINSON casted into the manifold. They are a decent manifold to feed a engine up to 6.25 stroke (M-450). Th intake alot beter in design, bigger than stock, and cost the same as a reproduction manifold. In fact,they are a direct aftermarket replacement. Was good for 3 more hp on a 6 inch SM all by itself, VS an original manifold. Chad
