Restoration & Repair Tips Board
J. D. 2520
baffled
11-04-2004 07:13:38
Problem: The engine(dsl) starts and runs fine but there is no power to the trans when the clutch is engaged. There is also no response from the loader or the rear lift. The clutch pedal moves freely so I'm assuming that the pressure plate should be ok. This is a synchro-shift trans if that is a clue. Please advise me if this problem seems familiar. I would like to hear what the likely causes could be (as well as the repairs and cost) before I delve into this. thanks for any ideas you can share.
msb
11-04-2004 17:15:10
 Re: J. D. 2520 in reply to baffled, 11-04-2004 07:13:38
Have you tried shifting the tractor with the clutch engaged?IF you have no hydraulics then the top shaft in the transmission isn't turning.I suspose the transmission could have been overshifted.If you get any response by shifting with the clutch engaged then it could be the shifter linkage is badly out of adjustment,but I have never heard of one that far off.
