Restoration & Repair Tips Board
JD 40 Muffler Gasket
Tony Byrd
01-09-2006 10:48:15
I have a 1954 JD 40-S. In the process of restoring. The new muffler did not come with a mounting gasket and engine gasket kit did not include such a gasket either. My manifold has been resurfaced, but without a gasket here, an exhaust leak is guaranteed. My old muffler/manifold joint had leaked, you could tell by the soot tracing. Has anyone resolved this and I missed it?
HoosierDave
01-11-2006 13:27:28
 Re: JD 40 Muffler Gasket in reply to Tony Byrd, 01-09-2006 10:48:15
I replaced the muffler on my 40 and found a gasket through one of the tractor parts suppliers. Now I just need to remember who that was...but they are available. I coated it up with antiseize to help seal and it seals fairly tight. Plus the muffler does bounce around at all.
HoosierDave
Tony Byrd
01-12-2006 20:25:46
 Re: JD 40 Muffler Gasket in reply to HoosierDave, 01-11-2006 13:27:28
Let me know if you remember where you got that gasket. I was thinking after I posted the original question that maybe a properly sized "donut" gasket would work. I measure tonight and the manifold ID is 2". I might give that a try if the parts store has a 2" OD donut ring.
Tony Byrd
01-17-2006 20:09:47
 Re: JD 40 Muffler Gasket in reply to Tony Byrd, 01-12-2006 20:25:46
I searched for an exhaust system donut gasket with a 2" OD that would fit snugly in the manifold, but did not have any luck finding one smaller than about 2 3/8" OD. Instead I purchased a solid brass lifting ring from Tractor Supply. The ring is 2" OD and rests on the seat inside the manifold,mount the muffler and tighten the 2 flange bolts. I am hoping that this will eliminate the blow-by and force all of the exhaust out the muffler. I will continue to search for a regular donut gasket of the proper size because I still believe that would be the best fix. I also still believe that this is a common problem that others encounter, evidenced by the smut under the hood.
