For the size of machine you are buying, and for the pressure you are operating at, a nice Hydrovane would serve you well. I have worked on compressors for over 10 years now, and for 60 hp and below, a Hydrovane makes a nice, compact air solution for high duty cycles and moderate pressures. Hydrovanes have several things going for them: 1) Plain bearings for the driveshaft. No expensive and difficult to replace taper or roller bearings to wear out. No preload or shimming issues, or end clearance problems when rebuilding. They often last for the life of the machine if they are not seized up from lack of maintenance. 2) Due to the fact that the compression element is not end loaded like a rotary screw, there are no high thrust loads to worry about. When a rotary screw is left to run past its bearing replacement interval, the rotors can travel the length of the case and seize up catastrophically. 3) Hydrovane rotor/stator units can run for hundreds of thousands of hours with simple routine maintenance, no bearing replacement required. 4) A Hydrovane is cheap to rebuild when the need arises. They are also pretty energy efficient, and can be had in variable speed configurations, but perhaps not in a low hp machine as you are considering purchasing. 6) They have a small footprint compared to most rotary screws, which can save you money when it comes time to build a compressor room. 7) Hydrovanes are relatively simple. Most competent mechanics could rebuild one with just a factory manual in a day or two. 8) Hydrovanes usually enjoy a significant cost advantage over rotary screws of the same Kw rating. Having said that, some people would gouge their eyes out rather than buy another Hydrovane. Usually, they have worked with them in an environment where they did not recieve proper maintenance, or where they installed in a poorly designed compressor room where they were allowed to run too hot and embrittle their seals (they leak oil ferociously if neglected, they are British machines afterall..) You won't go wrong buying a good quality rotary screw either. Unfortunately, in this HP range, you will find mostly belt driven machines, which raise their own maintenance issues. I am a Kaeser factory trained technician, and while they are superb machines, the belt drive can be a maintenance problem if they are operated in a dusty environment. Rotary screw air ends are usually spinning quite rapidly (unlike a Hydrovane, which is directly flange coupled to a 1740 rpm electric motor), and so they place quite a bit of stress on the belts. In a dusty environment, it is not uncommon for the drive pulleys to become severely worn in short order. Many small rotary screws are also used for a wide variety of HP ranges, and can sometimes be spinning at terrific speeds (8000-10000 rpm). this does not bode well for when someting goes amiss (ingesting a pop rivet from a cheap air cleaner cover for instance....). If you decide to go the rotary screw route, see if you can buy a direct drive unit. Quality brands are Quincy, Kaeser, Gardner Denver, CompAir (Makers of Hydrovane also), RotoComp, Atlas Copco, Sullair and, possibly, Ingersoll Rand. Avoid computer controls if possible, though the Kaeser Sigma controller is pretty trouble free. Rotary screw compressors are the workhorse of most industries and are not especially troublesome. They are more complex, more expensive, and require regular bearing replacement (about every 50,000 hours). Rotary vanes are cheaper, simpler, easier to rebuild, more compact,and quieter (arguably). They are also much less common than screws are.
