Converting 2wd ihc 1086 to fwd ihc 1086
David Hayes
12-11-2002 17:17:01
Looking to convert my 1086 to front wheel drive.
Can't locate a complete front end with everything i need to assemble my self including tires. And i was told this was and elwood mechanical drive system. I'm located by Minneapolis, Minnesota.
pain
12-13-2002 07:36:42
 Re: converting 2wd ihc 1086 to fwd ihc 1086 in reply to David Hayes, 12-11-2002 17:17:01
michigan dealer has complete unit ready to be mounted. I can get the number if you it.
mike
12-12-2002 19:15:21
do you mean mechanical front wheel drive or hydrolic front wheel drive
mak
12-12-2002 16:20:15
I think I know where there is one for sale in Pa. if I can find the add again. I have a number of an ELWOOD distributor for the 4wd aftermarket fronts. We had to get some parts for our MAssey 2805 that we converted to a 4wd tractor. What a beast, man that fwd axle does help. Email me if you want this info and I'll go searching. Good luck!
Salvage Man
12-12-2002 13:37:52
Find a factory kit off of a 1066, 1466, 1086, or 1486 tractors. All of these tractors came with an American Coleman front. And the late 86 series tractors had the Elwood fronts.
DONALD D. JONES
03-24-2004 16:02:43
 Re: Re: converting 2wd ihc 1086 to fwd ihc 1086 in reply to Salvage Man, 12-12-2002 13:37:52
There are two conversions out there
the T4-8000 light duty for field work only and
the Elwood 14,000 lb heavy duty axle
Parts are available at Trac 4 Inc Wilmington Il
815 476 5538 Barb will ship most parts in 48 hrs. Barb will help you with your questions or you can e-mail and Don will get back to you
Steven@nd
12-12-2002 10:33:11
Best bet is to find a 5088, 5288, or 5488 with the MFD already on it. The MFD option was not popular on the 86 series tractors.
jd green
12-12-2002 08:55:21
Would a unit off a john deere work if you could get the IH hudraulic unit to run it? I have seen very few IH units... I believe JD sold more of them, even they they are a pain to keep working properly. Not sure if this will help you, but it might be worth looking into. Good Luck
paul
12-12-2002 07:30:03
Sounds like an expensive project!
I saw one once at a farm auction, whole tractor. I'm south of you. Only one I ever saw, & i go to a lot of auctions.
--->Paul
Bernard le mécano
12-18-2002 13:05:42
 Re: Re: converting 2wd ihc 1086 to fwd ihc 1086 in reply to paul, 12-12-2002 07:30:03
Hi David, look for the model who have planetary, at the end of axle, not a big round cap.This one is cheap and not enough heavy.It's expensive to repair this one.For the transfer case ,the gear is in the transmission,that the park one. Bernard le mécano
