Tractor Talk Discussion Forum
I have a stupid question
Garry
09-16-2003 05:56:56
I have recently purchased a tractor that is still a six volt positive ground tractor. How do I check the electrical circuit? With a negative ground I would touch the wire to a ground (metal) on the tractor and the probe to the circuit I am checking. With a positive ground what do I touch the wire to. Does it work the same for positive or negative ground?
Garry
09-16-2003 13:40:30
 Re: I have a stupid question in reply to Garry, 09-16-2003 05:56:56
thanks guys for the help. this will help me get the wiring assessed.
Rob
09-16-2003 13:34:34
Like is said, the only stupid question is the one you DON'T ask! I've nothing to add about the previous posts in using a meter or test lite. You likely know this but if you're not familiar with electrics, you might want to check the polarity (+/-) of the ignition coil wires. The wire from the ignition switch to the coil is (-/hot) and the wire from the coil to the distributor is (+/ground). The coil posts will be marked (+) and (-).
Ben in KY
09-16-2003 11:18:51
Yep. If you are using a voltmeter you would place the positive (red / +) lead in contact with ground on a positive ground vehicle and probe with the negative (black / -) lead.
If you are using a test lamp polarity does not matter.
buck
09-16-2003 06:44:41
Check the same way-the sparks just travel the opposite direction.
