Tractor Talk Discussion Forum
This Looks Weird!!
Allan
12-11-2003 16:58:30
third party image
Hi Guys,
Here's the deal: I go and buy this little tractor, search frantically for a decent loader, find one and buy it.
Okay, I build this silly garage to put it in, making darned sure that it has 8' doors so that I can get the tractor in & out.
After the door seals are installed and the garage is complete, the tractor and loader will not go thru the door because of the upright reinforcement bar on the darned F-11 is 1/8” too tall!!
So, I go out there this afternoon and flip the darned support bar horizontal. I think it will work, won't it? I've seen other brands of loaders with just a box iron across the two uprights.
But, it sure looks weird!
Allan
bud sather
12-12-2003 08:36:53
 Re: This Looks Weird!! in reply to Allan, 12-11-2003 16:58:30
Allan,
I have a f-11 loader on my 2010jd. I turned the U pipe horizontal so I could drive it in the barn. I like it that way as it provides a handy hand hold when mounting or dismounting from the rear of the tractor.
Bud
paul
12-12-2003 06:00:52
Visibility has to be a problem with all the support & hosing in the way, but I don't see anything wierd looking.
--->Paul
Dave
12-11-2003 20:36:02
Drop a pound or two of air out of the tires =) That'll fix it
Larry NE IL
12-11-2003 20:21:53
Naw, what really looks wierd is a man dressed in ladies clothes!
rotten robert
12-11-2003 18:48:21
Weird? That's not weird! Weird is a Farmall H with a F10 loader on it.
D.L.
12-11-2003 18:18:29
Hey Allan, Whatever works, huh??? I've got a 400 w/an F-11; my upper support tube is bolted on the other (upright) way, but I can't think of any reason it won't work the way you've got it. I can't imagine the direction the tube is installed would have ANY effect on its strength, I've always assumed they built it as they did just for better visibility. Wish I had a garage to park my tractor in! I was definitely NOT in the mood for cold and snow!!!
D.L.
RJ-AZ
12-11-2003 17:54:36
I've seen quite a few F11's set up that way. Like they say it's only kinky the first time you try it. But whats with all the white stuff? Just another beutiful day here in sunny southern Arizona!!!
Larry NE IL
12-11-2003 20:19:36
 Re: Re: This Looks Weird!! in reply to RJ-AZ, 12-11-2003 17:54:36
We like to call that "white stuff" winter mosquitos! Come November, they multiply, land on the ground, die and pile up. Sometimes the wind blows them around and usually after a big hatching, it gets real cold. My grampa once told me that He had a friend He visited in Ariz. His friend was planting popcorn with a mule and the temp. was around 140 degrees.
It was so hot, the popcorn started popping, the mule thought it was snow and fell right over dead!
RayP(MI)
12-11-2003 17:09:36
Yeah, it looks weird, all right. Can you see where yer goin'?
Nebraska Cowman
12-11-2003 17:05:43
No Allan, it is not weird. My M is the same way.
Jerry
12-12-2003 17:26:00
 Re: Re: This Looks Weird!! in reply to Nebraska Cowman, 12-11-2003 17:05:43
Muffler looks higher than loader. How does that get thru?
