Tractor Talk Discussion Forum
Re: engine problem
RunnyNose Bob
12-24-2003 04:32:09
I doubt that spraying the choke plate caused your problem, as you say, you know about trickling ATF, Water, whatever down the carb to break up the carbon. However, I came to the conclusion 30 years ago that Champion spark plugs are pure s**t, and now since they are marketed for the DIY'er, and homeowner, there is no reason to think otherwise.
wdTom
12-24-2003 18:40:51
 Re: Re: engine problem in reply to RunnyNose Bob, 12-24-2003 04:32:09
I won't disagree that some plugs may be better than others, but it may have to do with the engine too. I have an 86 slant 6 and I had put a set of ACs in it. Ran OK but had a little miss once in a while, and not just right when pulling hard. I check and set and replaced everything I and others could think of, except the plugs as they were new. Then I thought "whet the hel*" it isn't much more money compared to what I have already spent to try another set of plugs, another brand. So I put Champions in, had always run them but store didn't have them when I put the ACs in, and it is still running great. Again, I won't argue that some plugs and some engines don't agree with each other, but I don't think you can condem one brand for all applications.
Champions
12-25-2003 05:28:56
 Re: Re: Re: engine problem in reply to wdTom, 12-24-2003 18:40:51
only good for chrysler products and lawn mower engines
