Tractor Talk Discussion Forum
CONTROL SPEED PLATE FOR FORD 8N
JOHN KNIGHT
02-09-2004 14:43:26
WHERE CAN I FIND THE PLATE THAT CONTROLS THE RUNNING SPEED OF THE TRACTOR? THE LITTLE BUMPS ON MINE ARE WORN OUT, SO I HAVE TO HOLD THE SPEED LEVER WITH MY RIGHT HAND WHEN OPERATORING THE TRACTOR.
greenbeanman
02-10-2004 07:02:20
 Re: CONTROL SPEED PLATE FOR FORD 8N in reply to JOHN KNIGHT, 02-09-2004 14:43:26
You might try this for a temporary fix as well---
Get some "friction washers" from the hardware store, a longer lever pivot bolt, add a spring, and install.
The spring should hold the lever tight enough against the friction washers and plate to keep it from slipping speeds.
Slowpoke
02-10-2004 00:28:33
Will this work? Get a small piece of ribbed rubber floor mat, set it on the lever quadrant with the ribs parallel to the gas lever. Mark it underneath, cut it to the circular shape and glue it to the metal. Or, cut a 2" length of 5/16 fuel hose, slit it down the side and place it over the gas lever.
Glue or tape it down between the lever and quadrant. It might get you by till a new one turns up.
norbert kanzler
02-09-2004 15:20:30
Try central tractor I think they are now called TSC
Stevens AG pARTS 1 800 333 9143 SELLS THEM
i HAVE AN OLD qUALITY fARM cATALOG 1 888 828 3276
Give them a call
