Tractor Talk Discussion Forum
Skyline Loader
Harold Cope
07-04-2004 20:14:49
I need to rebuild the control valve on the SkyLine Loader which is attached to my 1948 Ferguson TO20. Can't find another set of valves or parts for the old valves. This is a double unit valve which is mounted on a resovior. One lever operates the lift which is single action and the other operates a double action cylinder which works the bucket. The loader is a model 90-15-51. Can anyone help me out?
Paul Janke
07-05-2004 07:09:23
 Re: Skyline Loader in reply to Harold Cope, 07-04-2004 20:14:49
Forklifts without any frills would have the same valve configuration. If you had more spools for something such as side shift, it would give your tractor a place for a remote. My early 60's Hyster has the two spool valves mounted directly on the reservoir.
msb
07-04-2004 22:08:50
I suggest you try either www.northerntool.com or Burdens Surplus Center
