Tractor Talk Discussion Forum
weight of JD B and Ford 650?
Lynn Kasdorf -
07-23-2004 08:59:35
Anybody know off hand the approx weight of a 1947 John Deere B with filled rear tires?
And the weight of a 1956 Ford 650 with un-filled tires?
I'm assuming the JD will weigh a bit more than the ford. I have to trailer both and am wondering if I will have trouble hauling them on my 2 axle 16' trailer with brakes, pulled by my Chevy 1/2 ton pickup. The trailer axles are rated at 3500# each, but I suspect the frame would give way before that.
Matt Smith
07-23-2004 11:31:22
 Re: weight of JD B and Ford 650? in reply to Lynn Kasdorf - Leesburg, , 07-23-2004 08:59:35
My 1/2 ton GMC pulls my 640 WITH filled tires and 6.5' disc OR a 6' pulverizer on my 16' utility trailer just fine. It also has pulled an Oliver Super 55 with filled tires and the same pulverizer as well.
I do recommend having brakes on your trailer.
07-23-2004 11:38:07
 Re: Re: weight of JD B and Ford 650? in reply to Matt Smith, 07-23-2004 11:31:22
Ok, that is good info. I do have trailer brakes- 1 axle anyway and they work fine.
I only have about 15 miles to go with both machines and especially with the JD, I figure I'll go super early in the morning so I cna go slow and not annoy people too much.
Thanks
Farmered
07-24-2004 03:32:27
 Re: Re: Re: weight of JD B and Ford 650? in reply to Lynn Kasdorf - Leesburg, , 07-23-2004 11:38:07
If you have any doubts about it, play it safe and haul one at a time. Make two trips, it is only 15 miles. Is this a one time event or will you be making a regular trip? Ed
Dee in mid MO
07-23-2004 11:26:48
What I found: (no weights given for filled tires)
1947 JD B Approx Shipping Weight: 4130 pounds
1956 Ford 650 Shipping Weight: 2800 pounds (varied with options)
*** for JD from:>Link
***>Link for Ford from: Link
07-23-2004 11:49:42
 Re: Re: weight of JD B and Ford 650? in reply to Dee in mid MO, 07-23-2004 11:26:48
wow- exact numbers even! Thanks much.
