Tractor Talk Discussion Forum
timing IH656
John in Tx
12-05-2004 09:43:54
On my diesel IH 656 how can I tell when the number one piston is at the top of its compression stroke
K.B.-826
12-05-2004 16:14:34
 Re: timing IH656 in reply to John in Tx, 12-05-2004 09:43:54
There are timing marks on the flywheel. Remove the cover on the side of the clutch housing. The marks will be hard to see, so it might be a good idea to get in there with some sandpaper or somthing and try to clean them up. Next, remove the valve cover, and turn the engine until cylinder #6 exhaust valve is closing and cylinder #6 intake valve is opening. Stop turning the engine when the pointer in the clutch housing lines up with the 0 on the flywheel. You are now at 0 degrees TDC on #1. Your injection pump may be timed a certain number of degrees before or after TDC, which is why it's a good idea to get a manual.
Nebraska Cowman
12-05-2004 11:02:19
if you put your thumb over the sparkplug hole and turn the motor over slowly you should be able to tell.
John in Tx
12-05-2004 11:39:51
 Re: timing IH656 in reply to Nebraska Cowman, 12-05-2004 11:02:19
it's a diesel --- no sparkplugs
Bob
12-05-2004 12:03:38
 Re: timing IH656 in reply to John in Tx, 12-05-2004 11:39:51
You could remove a glowplug for the same effect, though, on this engine.
Bob
12-05-2004 09:49:12
Both valves on #1 cylinder will be closed, and the timing pointer will point to TDC.
