Tractor Talk Discussion Forum
delco alternators ? genorators?
k
12-22-2004 15:29:03
I have a 58 Case 6 volt positive ground, generator and VR system. Is there any way to put an alternator on with out having to change every thing over, Ive heard you can but its $$$$ for the alternator, my generator has 2 wires coming out of it a feild wire and a gen wire. Any help would be apprecated
Richard Fazio
12-23-2004 16:25:20
 Re: delco alternators ? genorators? in reply to k, 12-22-2004 15:29:03
K, send me an email. I unblocked mine. I'll forward you everything I have here. I sent a bunch of emails to another guy on this board and he installed the alternator and got everything working. I'll forward all the emails I sent to Russel. They list part numbers and wiring diagrams. If you go 12 volt you want to go negative ground.
Jrry
12-23-2004 06:29:32
try this:
http://www.ytmag.com/articles/artint195.htm
One wire Verses 3 wire
12-22-2004 22:46:50
Insite to the differences in alternators, maybe this will give you insight to how you want to change yours over. Go to "One wire compared to three-wire alternators
Keith-OR
12-22-2004 22:27:38
here is the wiring diagram for the change over.
Joe (Wa)
12-22-2004 19:49:20
Here is a link with some alternator wiring options.
Mike (WA)
12-23-2004 15:29:45
 Re: delco alternators ? genorators? in reply to Joe (Wa), 12-22-2004 19:49:20
Look at the wiring diagrams, but don't buy any of his alternators at the prices he wants- its over triple what they're worth. Go to the link below to get the straight scoop.
marlowe
12-22-2004 17:34:25
go to a good alt. rebuild shop and have them make up a one wire 6 volt pos. ground alt.for you then run a 10 gage wire from hot side of starter cellinoid make new mounting bracket. if your in wisc. i can give you the phone no. to a gay that did all of mine
wondering
12-24-2004 09:08:16
 Re: delco alternators ? genorators? in reply to marlowe, 12-22-2004 17:34:25
marlowe..i read this 3 times and gotta ask..how do you know he is gay????merry christmas!!!
Richard Fazio
12-22-2004 16:08:50
I changed my M over for real cheap. I think the Alternator was $54.00 plus an old core. Then you need a resistor to bring the 12 volts down to 6 for your coil, or change the coil to 12 volt. Do you have lights? Those will need to be changed out to 12 volt bulbs. With the new 1 wire alternators there is no voltage regulator, it's built into the alt. If your interested let me know, I'll get you all the info. The type of alternator and wiring. Mine worked out real good.
k
12-22-2004 16:55:56
 Re: delco alternators ? genorators? in reply to Richard Fazio, 12-22-2004 16:08:50
yes please I would like that info that would be great, will i need to change the lights out even if you have a reducer in place.
k
12-22-2004 16:58:05
 ps.Re: delco alternators ? genorators? in reply to k, 12-22-2004 16:55:56
is this all ok with a positive ground thanks again
