Tractor Talk Discussion Forum
Won't start
Bob Roden
02-17-2005 07:46:48
I have a MM 445 that started several months ago, but it will not start now. I changed the ignition switch, starter switch and the soleniod and the battery is charged. The power gets to the right side of the soleniod that is hooked to the starter and makes a clicking sound but does not crank. Before I changed the solenoid that wire would smoke and get hot, I need help. I have snow to plow, Thanks for any help.
leland
02-17-2005 09:08:37
 Re: Won't start in reply to Bob Roden, 02-17-2005 07:46:48
try tapping starter with hammer firm not a hard wack sometimes this helps
Joe MD
02-17-2005 08:48:39
If this type of tractor has a ballast resistor it may have gone bad.
bo
02-18-2005 05:50:32
 Re: Won't start in reply to Joe MD, 02-17-2005 08:48:39
A ballast resistor won't stop the starter motor from spinning..it'll start...but shut right off.
bo
02-17-2005 08:21:46
It could be the starter but it that's easy to check, run power direct to the starter from another battery and a set of jumper cables. If it's not the starter, find the starter relay and replace it. Follow the wires back from the starter selonoid and they should be to the relay.
Bob
02-17-2005 08:16:00
With the ignition "OFF" for safety, try turning the engine over by hand with a crank or other means. This will verify that it is not stuck, and the starter is not jammed against the ring gear.
Bob
02-17-2005 08:15:54
old
02-17-2005 07:57:35
Pull the starter and have it checked sounds like it maybe bad
bedrock1234
02-17-2005 09:21:11
 Re: Won't start in reply to old, 02-17-2005 07:57:35
I would check to make sure the starter is not locked up first like one of the previous stated by turning over by hand or with a crank.
