Tractor Talk Discussion Forum
starter bendix 48 8N
RJT
08-06-2005 12:55:58
I installed a new bendix. Put the bendix on the starter shaft and . . .. .
The first time or two both the starter and the engine turned over. Now the starter turns, but the engine does not.
Pulled it out and it looks fine, but . . . still not working when re-inserted.
MarkB_MI
08-06-2005 19:04:19
 Re: starter bendix 48 8N in reply to RJT, 08-06-2005 12:55:58
Did you replace the starter ring gear on the flywheel when you did your rebuild? If not, then a tractor split may be in your future.
Pull the starter and take a close look and the condition of the ring gear.
geok
08-06-2005 18:07:21
Take starter out and try to spend motor over by prying on the ring gear. Sometime the ring gear loosen and spends on the flywheel.
Gene Davis (Ga.)
08-06-2005 16:58:28
You say it turned over a couple of times. It may have siezed due to too little clearances, or it may have water or possibly even gasoline in the cylinders causing it to have a hydrostatic lock. Disconnect the wire from the switch to the coil and tape it up to prevent a fire while trying the next step. Take the spark plugs out and see what happens wehen you turn it over with a hand crank if possible. if you don't have a hand crank, then try the starter with the plugs out. If it is water, you have a cooling system leaking through something like a cracked head, or a sleeve, or a head gasket not sealing. If the cylinders are not filled, then you may have an issue with a bearing or something too tight. If this is the case, you may need to consult with the engine rebuilder. Just a thought, but be sure you aren't trying to crank it in gear.
RJT
08-06-2005 15:12:17
 Re: starter bendix 48 8N -- more in reply to RJT, 08-06-2005 12:55:58
I had this motor rebuilt this past winter/
spring and have not had it running since then. Time has been limited and the temperature finally dropped so I felt motivated this weekend. With that said, I went out and thought I'd do the last of the electrical (all new harness and 12 volt) and get it going today.
I thought after my last post it was a weak starter, so I went and bought a new one with a new bendix just to be sure. Installed the new starter and it turned the engine over a little, then it stopped turning over the engine. The starter is still working, but it can't turn over the engine.
Took out the plugs and tried to turn it over w/o compression. Still starter buzzes, but it can't get the engine to turn over. This sounds like something binding within the engine, but I am looking for advice before I call up the machine shop (who also assembled it) and get them in the game.
Anything someone with tractor experience might have to add?
RJT
08-08-2005 07:53:34
 Re: starter bendix 48 8N -- more in reply to RJT, 08-06-2005 15:12:17
Great advice. I did replace the ring gear (the machinist did) when did rebuild. I'll take the starter back out and try to spin it.
I tried to push the tractor (by hand) while in 4th gear, but can't get engine to spin. I also pulled the plugs and tried to spin with starter, but no engine turning.
Have made sure it is out of gear.
Once again, thanks for the replies. I had another on a different board saying to make sure the battery is truly good. I need to try that too.
RT
