Tractor Talk Discussion Forum
slow loader operation
bob calimer
08-08-2005 20:28:04
hi ,
i have a 2110 ford that someone installed a front loader !
problem is it moves too slow ?
lookes like it is plumed to work off the divertor valve ? also has some other aluminum block that is installed between hand controlls and divertor valve . no numbers or identifacation except the letter z stamped on one corner ? block has a 1" hex about 2 " long coming out one side ? may be a relief valve ?
do i need a second relief valve as one is in the divertor valve ?not sure what it is ?
loader is a 776 A .
thank you
Don-Wi
08-08-2005 20:45:28
 Re: slow loader operation in reply to bob calimer , 08-08-2005 20:28:04
Is this a new to you tractor? I'm guessing it doesn't have remotes on the back either. Chances are, the only way to speed it up is to use either a pto pump or a pump driven off the crank shaft. Either can be had, but have the check book ready. Some of those components aren't cheap.
Donovan from Wisconsin
