Tractor Talk Discussion Forum
Farmall 706 will not start
Tod in Ohio
05-28-2006 15:27:05
I need your help. I was running my Farmall 706 diesel. I turned it off went in the house for about a half hour came back out and the tractor will not start. It does not even click. I checked the resistor and the battery terminals and the tractor still in not start. The flashers, horn, and lights all work. Does anyone have any ideas?
Thanks in advance.
Tod
TimWafer
05-28-2006 15:34:55
 Re: Farmall 706 will not start in reply to Tod in Ohio , 05-28-2006 15:27:05
Maybe safety switch on clutch??
Cliff Neubauer
05-28-2006 16:37:14
 Re: Farmall 706 will not start in reply to TimWafer, 05-28-2006 15:34:55
The clutch saftely switch would be my guess too. Sometimes they need readjusted or if your careful you can pull the plug off and use a short wire with male spade ends to loop around the plug to bypass the switch.
