Tractor Talk Discussion Forum
NAA no oil pres.
Fchef
06-17-2006 04:30:49
I am new to this game so please cut me some slack. I am the owner of a 53 Ford NAA tractor,after working on the charging system(6v)it has started. The proofmeter does not work and the oil pres. guage does not show any movement, I changed the oil and filter (spin on type )The oil was very dirty,But had no gas smell. How do I check The guage, oil pump to see what my problem is .It starts and runs ok,some blowby from the oil fill.Also I need to find the pipe or tube that runs from the oil bath air cleaner to the carb.Thank you all this a great forum Fchef
old
06-17-2006 08:02:07
 Re: NAA no oil pres. in reply to Fchef, 06-17-2006 04:30:49
First thing I would do is remove the line going to the gauge and turn the engine over but don't start it. There just like the 8Ns and will turn the engine over with out the ignition switch on. If your getting oil preassure you should have oil comeing out the line when you turn the engine over. If you have oil there then its time to replace the gauge. If you don't then you neeed to look deeper in to what is wrong
Bob
06-17-2006 08:00:20
If there is no oil pressure, you should not be running it long enough to worry about the charging system, or any blow-by out the breather!
Especially if it has been sitting for a while, and the bearings are bone-dry of oil, you have probably "toasted" them already!
To verify that it is not simply a stuck gauge, disconnect the oil line to the gauge, at the engine block. Then, crank it over and see if any oil is pumped out. If not, DON'T run it any more 'til you find out what's wrong!
The oil pump screen could be sucked full of debris, or the oil pump could have failed, or simply need to be primed.
"Pro" engine builders have a pressurized cannister to prime engine lube systems before startup.
If the tractor sat a long time unused, and you want to try to prime the oil pump and lube system, you can try this:
For one-time use, you can get a new pump-up garden sprayer for about $9.00, then cut the "wand" off before the nozzle, and use a piece of gas-line rubber hose to connect it to a fitting screwed in the block, where the oil gauge connect is. Put some clean, fresh motor oil in the sprayer, and pump it up, forcing the oil into the engine's oil galleries and oil pump.
After doing this, put the fittings back as they were, and you will either have oil pressure, and be able to run the engine, and evaluate it's condition, or, if still no oil pressure, the oil pan will have to come off, for access to the oil pump.
