Tractor Talk Discussion Forum
Drawbar Hole Size Question ?
MMB
11-12-2006 19:25:28
Question here on what the original size of the drawbar rear hole should be on my tractor? Actually, it is a MH 20 (1946) but was there any "standard" used for those sized tractors (say between 2500 - 4000 pounds). most of those drawbars seemed to be 1" thick by 2" wide. What should the hole size be? I am making up a brandnew drawbar and the old one is so messed up with cuts and welds and bends a guy can't tell anything for sure.
Dave Sherburne NY
11-13-2006 10:05:37
 Re: Drawbar Hole Size Question ? in reply to MMB, 11-12-2006 19:25:28
You probrobly wont use anything bigger than a 3/4" pin why go bigger than 7/8".What size hole is
in your attachments?
MI Mark
11-13-2006 06:45:47
don't waste time with the odd size of 7/8 go 1inch and use a wider or thicker drawbar .It's pricey but they make a fatige proof steel that works good or a higher carbon steel to not bend as easily
dboll
11-13-2006 06:23:10
on CC/RC Cases I cut out the hole and insert 1" id pipe then weld it in and grind it down, makes a nice round hole.
Don L C
11-13-2006 00:12:43
If I was going to drill a 7/8" hole, I would go a bit wider with the bar than 2"..... .maybe 2.25 or 2.50".... Don
135 Fan
11-12-2006 22:14:19
3 pt. draw bars have 3/4 inch holes. Check what size holes are in most pull type implements. If the hole is bigger it will allow more sizes of pins to be used. It isn't real critical so maybe a 1 inch hole would be better. 3/4 inch pins can bend and wear quite a bit under heavier pull. Just a suggestion. Dave
steveormary
11-12-2006 20:51:32
MMB
I would agree that a 7/8" hole should be drilled in your drawbar.
steveormary
Gerald J.
11-12-2006 19:32:32
I agree. A 7/8" hole for a 3/4" pin to allow for tongue twist and rise and fall of the implement with respect to the tractor.
Gerald J.
msb
11-12-2006 19:29:19
Can't answer that question, but I would drill a 7/8" hole in it.
