Tractor Talk Discussion Forum
travel
LBSMJS
03-02-2007 05:39:07
I need to be in Rocelle,Ill. Sat. morning.Leaving from NW Iowa.How,s the roads & visibility that way.Thanks for all info.
NE IA Dave
03-02-2007 21:00:23
 Re: travel in reply to LBSMJS, 03-02-2007 05:39:07
Perhaps not impossible here in NE IA, but I went two miles this afternoon and turned around. Many times just had to stop and wait for visablity and no safe place to turn around. Snow plows are getting stuck on gravel roads, I have not seen a snow plow since it turned dark on US HWY 52, the 52 runs Nort and South, everything canceled. I don't think there is much on the fields as it seems it is all in my yard. It seems most opinions are the same, anyway good luck if you decide to try.
GentleBen
03-02-2007 09:29:30
LBSMJS if at all possible delay your trip. I'm near Rocelle and its a whiteout and snow drifting very bad. Lots of roads closed in the area..... ...Ben
gene bender
03-02-2007 08:11:57
Cant you get WHO 1040 on the radio they have up to date. WMT 600 says eastern IOWA STAY OFF ROADS.
Gerald J.
03-02-2007 06:57:29
Iowa is closed for the day. Drifts have to be tall with the 50 mph winds. I have only 6' to 7' in the front yard drifts. There's another inch of snow forecast for the day. Roads aren't being plowed. Whatever is in Illinois probably will go on without you.
Gerald J.
LBSMJS
03-02-2007 06:45:07
I,m thinking by 3 or 4:00 this afternoon I,ll be able to leave.I need to move some snow here at home & then finish a tractor at the shop.Also need to move another in to thaw out for next wk.
gene bender
03-02-2007 06:22:54
Here in eastern IOWA i-80 no good travel not recomended. How are you even getting out of nw IA
LeRoy DeLong
03-02-2007 05:46:12
try this site
http://www.weather.com/activities/driving/interstate/roadconditions.html?from=interstatefl
