Tractor Talk Discussion Forum
case thermostat
matt delong
04-29-2007 19:59:52
questions about a case thermo, anyone that can help i would really appreciate it. thanks
matt
Joe (Wa)
04-30-2007 09:43:11
 Re: case thermostat in reply to matt delong, 04-29-2007 19:59:52
All the 300 series tractors with gas engine had a t-stat mounted in the hose between the cylinder head and the radiator. T-stat seats on the elbow bolted to the head.
Joe
matt delong
04-30-2007 05:49:23
i"ve got a case tractor with the 300 decals on it, however there is nothing else on the tractor that matches up with a 300 series case. it has no spot for a thermostat and i was told by somone that some of the older cases didn"t have one. is this true? if not where is it located, i removed the housing where 99.9% of thermostats are located and there is nothing there, plus the coolant port is square. no recesed machining for a thermostat to sit in. let me know what you think.
thanks
matt
RAB
04-29-2007 22:32:33
Err? What is(are) the question(s)?
