Tractor Talk Discussion Forum
Has anyone ever seen a Chrysler slant six in a tractor?
garyo
08-19-2007 12:19:48
I'm just curious. I know they were used in combines.
Gary
Badly Bent
08-20-2007 05:14:06
 Re: Has anyone ever seen a Chrysler slant six in a tractor? in reply to john in la, 08-19-2007 12:19:48
I think that several tractors used the Chrysler 6 cyl engines. One I have personally seen is a Custom Mopdel B tractor (I think the Simpson was similar mechanically), and that engine is a sweet sounding piece of equipment.
[/img]
charley hellickson
08-19-2007 23:47:04
 Re: Has anyone ever seen a Chrysler slant six in a tractor? in reply to garyo, 08-19-2007 12:19:48
Hi Rich Iowa.
Where did you see that tractor at? Moss Bros. In Dallas Center had a tractor like that. I knew the guy from Granger who built that tractor. It was a slant 6 in a CA AC. He also put a wide front end on it. He did every thing except some of the machine work. He had a wedge shaped spacer made to turn the manifoldes upside down. Exauhst on top, carb on bottom. He showed it at Waukee one year. Moss sold it and I saw it over at the Marshall Town show, some guy over that way bought it. Theodore also put a Chrysler 331 hemi in a WD AC, looked like factory. That man was a great mechanic and a mopar man and mechanic. Slant 6 was never put in a tractor from the factory, just the flatheads. Custom put a Chrysler straight 8 in some of his tractors. I have seen one. Massey 300 combine had a slant 6.
Thanks. Charley.
LenND
08-20-2007 13:54:14
 Re: Has anyone ever seen a Chrysler slant six in a tractor? in reply to charley hellickson, 08-19-2007 23:47:04
Yes, I owned a Massey combine with the slant six-300 model. Nice combine but was awful small, I think only a 30 inch cylinder. But it sure would pure along nice.
dobber
08-19-2007 19:25:19
Ran them on irrigation pumps and keep the oil changed it didn't take much at overhaul time usually just valves and back with standard rings and maybe a water pump. Oh yeah had to keep a few of those plastic distributor gears on hand. Usually sheared off when a rain killed the engine.
LenND
08-19-2007 18:26:43
I have a Massey 36 swather with a slant six. We swathed about fifteen hundred acres every year and it still has original engine. Only thing we did was put a couple carb kits in and regular tune-ups. Never had any of the covers off. In fact I have a 36 for parts with a good one in it I wpuld like to put in a tractor someday.
Bob
08-19-2007 18:15:40
 NO, but they worked GREAT in swathers... in reply to garyo, 08-19-2007 12:19:48
Hesston used them, as well as DEERE, and perhaps others.
Delta Bob
08-19-2007 17:52:56
I ran across a tractor a while back that had a Pinto engine and trans. and another with a Ford V-6.
Bob N.Y.
08-19-2007 16:32:20
I remember seeing a Cockshutt 50 that someone had tried to put a slant six in. They made quite a mess of that tractor.
Rich Iowa
08-19-2007 12:43:58
About 5-6 years ago when I was still in high school, I was looking at tractors on a dealers lot and saw an Allis Chalmers with a slant six in it, I want to say it was a AC C but I could be wrong. The salesman said an old guy traded that in, said it basically dropped right in and really woke that little tractor up.
IH2444
08-19-2007 15:27:50
 Re: Has anyone ever seen a Chrysler slant six in a tractor? in reply to Rich Iowa, 08-19-2007 12:43:58
Those slant 6"s were good engines. I put 1/4 million miles on one in a Volare. Rreplaced darned near everything on the outside of the engine a time or two but never had the rocker cover or oil pan off. well I did have to replace the rocker cover gasket once.
Changing the starter was a 15 min job hanging over the fender :)
Good thing too , they seemed to last about 50K.
730-LP
08-19-2007 12:34:23
I have two LEHR BIG BOY's that have chylser flat head 6 cylinder engines.1 is tricyle and has a 251 engine ,the other is a standard and has a 232 engine.
